Question for ECM Link users... logging boost...
SleepinGVR4
Danville, Pennsylvania
Ok so I wanted to install a map sensor to log boost but here's the problem....
I run an EVO 8 MAF and want to keep my factory 02 sensor. The only way I see I can do this is if I move my WB to the factory 02 position on the 02 housing and use the narrowband simulation option on ECMLink.
One of the reasons I don't want to do this is because I'm using an AEM WB and like everyone knows their not 100% accurate with ECM Link. Plus I'd have to rewire it at the ECU again, by moving the one wire from the EGR pin to the 02 pin.
And I can't use any of the other pins on the ECU because I'm still running a Mitsu MAF. /ubbthreads/images/graemlins/banghead.gif
I wish there was another pin on the ECU to log from.
Anyone know what I'm talking about?
spooling92vr4
long island, NY
Yes, you seem to have hit the nail on the head.. you would have to use narrowband sim and use the egr to log boost. Unless you get rid of the Mitsubishi maf by switching to sd or gm maf translato.
mikus
Aurora IL
yup, you're changing hardware or you're busted. Hop on the SD bandwagon, you'll open a few up.
SD FTW all you need is a GM IAT wired in and a good tuner. I switched without a compensated maf and had zero trouble dialing it in. I just slowly made adjustments to the VE table til everything lined up.
