ptb issue, running weird!
4doorboost
Westlake Village, Cali
so m car is running really weird. i am getting cut, stumbling at part throlttle pretty bad. at full throttle my car runs better and and very low throttle. my afr is also reading lean sometimes, like 16+ when im cruisin nd occasionaly will just sit at 21. im gunna check for leaks but its having weird syptoms for leaks. im thinking it could be the tps sensor is not calibrated correct. any suggestions or easy ways to calibrate it? any suggestions on getting to that lower screw or if something else may be the problem. thanks
bryce ocain
4doorboost
so now when i start my car the zeitronix reads arouns 14 15 but then as i get going it sticks at 21 and stays there although the car seems to run ok. souls it be the zeitronix? or does my car just go lean i dont understand because even at wot now once the afr hits 21 on the zeitronix it stays there
yeti
san diego california
I'm thinking something bad would of happend already if your going wot multiple times. At 21.
I'm geussin check the wideband
4doorboost
yeah i only went wot once for obvious reasons.. my setup= fully forged aluminum bottom end, big 16g, hks cams, i run an safc2 for fuel, not sure on the injector size cause it had the injectors when i bought the car but not stock, never had a fuel problem, 2g maf. i recently replaced the throttle body shaft seals and throttle body gaskets, and all of the upper and lower injector o rings.
4doorboost
well when i replaced everything to get rid of boost leaks its just been stumbling pretty bad at part throttle and wot. i also think i might have not set the tps correctly so im gunna check the voltage later, but just dont understand why when i start my car the afr reads fine then after about 10 minutes of driving goes straight to 21 even when i shift
4doorboost
so the part throttle issue was bad wires at the tps. but still when i start my car the wideband reads fine thenit goes to 21 and sits there after a few minutes, how could it read ok in the begining then just changeif the sensor was bad? this just started and its getting worse
Adorsey
mass
You still have a FIAV(Fast Idle Air Valve) on your throttle body, which runs coolent thru the tb to help the warm-up process. The fiav shuts off after the motor is to temp, the motor raises its idle and gets more fuel ( ! ) to warm the motor (Thats when your a/f seem okay). When the job by the fiav is done, it shuts off. And leaves you with your current settings on your safc ( Low a/f ratio ).
Find some one with experince with an safc. Give him some money. And go for a drive..
GL
Editied for misleading information~
4doorboost
road racetuned my safc2 so i think its on.. i do have the fiav but th idle is perfect and the afr is fine then just randomly will go to 21 and sit there while the car seems to run fine.
