Prosport wideband & volt
Hondakiller
Deltona Florida
I just got a prosport wideband gauge. But not sure how to wire up the read wire for the gauge.
Wiring instruction:
Red-12v Accessory power
Black- Ground
Yellow- 12v power
Now this one
Grey- Output signal off the O2 sensor.
So do I splice into one of the wires off the O2 sensor? Or.
Wideband user's:
If you intend on having this gauge work like a wideband will need to install the grey wire on a LC-1(or somthing similar) out put signal. You will also need to change the setting on the back of the gauge to 0~5 volts.
Now what is a LC-1?
I have a scanmaster 3 can I wire the gauge to that?
Thanks
Matt
Rausch
Cleveland, OH
Lc-1 is a wideband O2 setup. 0-5v sensor, etc. click
To pull a narrow band signal (regular O2), you need to tap the signal wire somewhere between the sensor and the ECU.
citymunky
Chesapeake, VA
+1
I have a LC-1,I tapped into the O2 signal right off the ECU yellow connector. Just find pin-out diagram for the ECU and the rest should be cake.
broxma
San Antonio Tx
The LC-1 is a specific sensor controller made by Innovative. The 3 wire sensors will not be wideband sensors.
The LC-1 is actually the controller unit. The O2 sensor itself is nothing more than the OEM sensor from the 1.8T Volkswagen. You can get the sensor at Advance/VatoZone for like 50 bucks.
The LC-1 requires power ground, and a calibration ground. The output is 0-5v and connects to the O2 input on the Prosport gauge. The Prosport gauge has a switch on the back which switches the voltage range from 0-1 to 0-5, in other words, narrow band to wideband. In addition, you can also turn on or off the initial start up voltage display in either O2 range.
If you connect your three wire to the prosport gauge, switch it to narrow band (0-1v). If you get an LC-1, you'll switch it to the other voltage.
/brox
Hondakiller
Deltona Florida
Ok thanks I was confused with a/f was wideband. Dont have everthing to do wideband. But I have the gauge hook up as a/f and volt. But thanks for clearing it up.
If you have the prosport wideband kit, which includes a wideband sensor, you don't need anything else. Not sure how you ended up with just the gauge if that's the case unless you bought it used.
