Power steering switch connector.
gvr4ever
central Indiana
Could someone please attach a picture of the connector that connects to the power steering switch?
About the only thing not sorted on my car is the PS switch is not blipping up the RPMs when parking.
KiNgMaRtY
Corona, CA
Did you put in a new reman PS pump? It is very sensitive to the piece with the spring inside. You must remove it and put it in the PS pump for it to work properly. I had a similar issue in a prior VR4 and could not solve it. Bought an OEM used pump and put in those pieces in the reman pump and problem was solved.
gvr4ever
central Indiana
I did try a reman pump, but the original had the same issue. I'll have to look into the spring inside. I've been delayed by a stupid annoying wrist injury.
