Power steering issue
Gtpdz
Gig Harbor, WA
Has any one have a similar issue where the power steering only works when turning the steering wheel to one side?
thomcasey
Indianapolis, IN
I have seen it where it will absolutely not move in one direction temporarily but never fails when the PS pump is disabled. But, what you are describing is a definite Rack issue as the PS pump doesn't care what direction you turn.
Gtpdz
Gig Harbor, WA
Thanks, that's what I have been wondering about, will try to swap in a different one and see how it does.
toybreaker
iconoclast
Before tearing into it, I would eyeball all the external lines
A kinked / restricted external crossfeed line (external to the rack) can cause this.
Does this vehicle still have aws?
It's *possible* that damage to one of the feed lines to the rear rack could also cause this problem on an aws equipped vehicle.
If all the external stuff looks good, it may be a damaged spool valve (internal to the rack)
Gtpdz
Gig Harbor, WA
the vehicle still have all the 4WS device and line hooked up, Iam not sure if it works, is there a way to check that? although no visible leak outside though.
Gtpdz
Gig Harbor, WA
Finally taking a look at this issue, looks like the rack has been rebuilt before with Koyo steering gear, however one external cross feed line that goes into the left chamber was crushed (car once bottomed judging by the dent on the down pipe below). So I guess that's the reason here as the car has very little ps when turning left.
Will try replacing this line with the rack on the car and see if it goes away.
