Power Steering Belt and Alternator problem
SiennaLover69
citrus heights, california
So, a couple days ago as im driving, somehow the power steering belt just flips around, it does a complete 180 and the teeth are facing the other direction. It happened as I was trying to speed through a light, I switched gears too quickly and released the clutch too early. The belt was really worn on one side and old so I figured that might just be the problem. I cut it off and drive with no power steering home.
Fast forward to a few hours ago, I get the alternator belt off and im able to just slide the new power steering belt on without removing any bolts from the power steering. I hadnt moved it around at all, nor did it look like its been move around or anything, also I know for sure its the right belt.
Also on an unrelated note I notice that the alternator is really wobbly, like I can move it side to side about half an inch. I tried to just throw back on the alternator belt and drive with now power steering for a few more days but now the alternator belt isnt tightening all the way.
Ive gotta head to work, lol, ive gotta bum a ride, so ill try to add more info if I need to throughout the day if I can!
Thanks in advance!
You do realize that the alternator belt also drives the water pump, right?
I wouldn't be driving it at all. Also I'm having a lot of trouble believing the belt "flipped". You need to correct the alternator wobble and replace the belts. Start there. Make sure everything in bolted down and there is no play in the pump.
desant78
Clarksboro, NJ
dumb question, is the alertnator and power steering pump properly tensioned? are all bolts that hold them tight? Lastly, is the pulley on the water pump tight? Does that pulley wobble?
I know it's the silly basics, but that is exactly where I would start. Good luck!
