Piston Rings
LordAthey
Council Bluffs, Iowa
Okay so the whole story starts as i was driving my car got home and turned it off. Go to start it up the next morning and it sounds like a rod snapped, cause there was a long clanking noise. So i dropped the motor took it all apart come to find out all the bearings were good the rods are fine, the pistons and the cylinder walls look good as well. So while i have it apart i'm going to put new bearings and piston rings in it. Now the problem here is it has JE pistons in it. I have no idea if its bored out or not and there is no part number on the pistons. So just wondering if JE makes standard pistons or if there oversized. If there is any way to get the part number for these pistons, so i can buy rings.
Just take the piston/rod combo to a local machine shop and have them give you a measurement. Then call je and ask them to tell you where to find the P/N and then you get your rings.
