P/S System Parts
GEDengineering
Miami, Fl
I recently purchased a gvr4 and it can with out a working p/s system; meaning no pump, reservoir and lines. I was able to rebuild the rack along with fabricate a reservoir but I am having a hard time sourcing some of the little parts.
These are the following parts I was hoping to get some help finding;
- The pressure switch that goes in the lower port of the pump for the ecu to raise the idle when the pump adds load to the engine. Or just a simple plug will work for me.
- I also need the suction fitting that attached to the return side of the pump
If anyone could help me out that would be great or anyone that has an old pump they don't want and would be willing to hook me up with the parts I am missing
Thanks
GEDengineering
Miami, Fl
I deleted the rear steer when I rebuild the rack. I have been looking for a few DSMs in my area junk yard with no luck
GEDengineering
Miami, Fl
Does anyone at least know the diameter and pitch of the threads or know of a plugs that would seal the lower hole any help guys
