Overboosting after afpr install
TakumiJr
MA
After the afpr install today the car is now overboosting past 25psi without the boost controller installed. Any help is greatly appericated..
Mods are
-Sleeper 16g
-FIC 850
-ECMlink V3
-SX afpr
onesickcrx
NY
Is it possible that your vacume line too afpr is same that goes to wastegate? and if so its cracked or not hooked up any more?
TakumiJr
MA
No, I also double checked and put a new vaccum lines also. It will only overboost in third gear also.
onesickcrx
NY
well in that case sounds like wastegate doesnt open up soon enough or its to small
donniekak
surprise az
Quoting TakumiJr:
Impossible, if the only thing that changed was the afpr it is not possible for a fpr to affect boost, unless the vac lines were messed up.
onesickcrx
NY
I thought about this last night the only other way other then vacuum line being the issue as I suggested before. If your car was so rich by over running the stock regulator it could have been holding the car back by flooding it and not allowing it to run smooth and make the correct boost level and fixing that may have made it over boost by making it run in a correct fuel curve.
Let us know what you come up with tho...
TakumiJr
MA
Thanks I believe you are right, because I was having a hard time starting the car up after leaving it overnight with the stock fpr.
