Old CAPS I have laying around...
Oner
Active member
Florida
As the thread title states I have an old CAPS that I just found in a storage bin...what could I do with it? I used it on an old Pentium 3 I had back in the day so know it should still work.
Decoration? I have loads of those myself. It will still work, just won't have latest part numbers if they have been superseded.
I think those went away about 2008 or so when they went to the new CAPS.
Also should note if anyone does still use these, I have export versions as well if anyone is interested in the data. I think I even have some JDM versions (which I may not part with yet).
Oner
Active member
Florida
Thanx. I will put it on the shelf with the other old stock of stuff.
DSSA
PA
You can download a cracked version of ASA off of Mitsubishilinks.net
I believe it only goes to 2008, but you should be fine with that.
The Euro and JDM files can be found quite easily and loaded into the file once you have it working
