Oil squirters
kooter
carpentersville, IL
do you mean to put it back in with the tube broken off, or leaving the entire thing out. I would think leaving it out completely would cause a problem with oil pressure.
But that is just what I would guess.
Steve885
Concord ca
The pistons broke off the tubes (not my build ) the guy working on my car is having a hard time with them. I'm just wondering if its ok to just let them squirt down into the oil pan rather then plug the hole or block them off..I've noticed some people block them when they build their engine using forged pistons..
fuel
Toronto, ON, Canada
I would say it would be a bit of an oil pressure drop if the oil squirters were simply removed without being blanked off.
It depends on if the tubes broke before or after the check valves in them. If the valves are there and work, it shouldn't be a big deal to just let them squirt. Personally I would replace or block them off though. You will see an increase of oil pressure, but IIRC it's not a huge increase.
theevozero
Odessa, Texas
^^^THIS^^^
YES, if will cause an oil pressure issue if you leave them out! Like, kiss your bottem end goodbye in 60 seconds or less.
Fiascoxl
Stuarts Draft, Va
Not to thread jack, but what does everyone use to "block them off". I am assuming a simple bolt an crush washer deal?
EMX5636
Bucks County, PA
Check valves are part of the banjo bolt. The rest is just hollow. I would block them off if you aren't going to buy new ones and tweak them to clear your pistons.
Wizardawd
Franklin, NC
I've always used new oil drain plug bolts. Correct pitch, depth and come with a nice new crush washer.
Wiz
EMX5636
Bucks County, PA
Quoting Wizardawd:
Wiz
+1.
EHmotorsports
Beaverton
Quoting Wizardawd:
Wiz
+2 and use red loctite
5OF2k
colorado springs, colorado
I always remove them. As stated above, the proper tune will void the need for the squirters, and IMHO, if youre spinning the motoe past 7k(honestly, even if youre not), the extra oil pressure is never a bad thing. Bearing like oil, let em have it!!
-Jake
