oil light...
SleepinGVR4
Danville, Pennsylvania
Ok my oil light just started coming on. Its doing it at idle and when i'm taking a slow turn. The idle isn't dropping below where its set. I just started to do this. Yes I have an oil pressure gauge but it stopped working a month after I installed it. Stewart Warner junk. I just built this engine 5K miles ago. Any ideas?
ktmrider
Tempe, AZ
Could be a variety of things from the engine rebuild ( poor bearing clearance, oil pump failure first come to mind ). Any unusual noises from the engine or leaks?
Describe the rebuild including parts AND their brand ( OE, Felpro, etc ).
SleepinGVR4
The valve cover is leaking like there is no tomorrow, I figured it was due to not have the pcv system hooked up correctly (dual catch can etc).
The build...
The head was cleaned up and had new valve seals installed.
The block has ACL race bearings, eagle rods, ross pistons (bored 0.030 over), and a Felpro MLS head gasket.
1990ggsxnj
Blackwood, NJ
I would get another gauge on there. Normally when it goes on while turning, you're starving the engine as the oil is going away from the pickup tube. This sounds like a stupid question, but did you check the oil level?
It may have been running out so much from the valve cover that the level dropped to the point where there wasn't enough to maintain the pressure.
SleepinGVR4
No oil isn't low. I just changed it and checked it today. As for a loose wire, it could be but I replaced the connection on the wire and the sensor when I built the engine.
ktmrider
Tempe, AZ
+1, all speculation until you install a gauge of some type.
Also did you replace the oil pump or do a BSE during the rebuild? Many of the non-OEM pumps ( most notably the TopLine product ) are notorious for failures. Doing a BSE without an OEM stub shaft ( or grooved model ) has also lead to many failures too.
1990ggsxnj
Blackwood, NJ
Is your oil pan bent upwards, possibly preventing the pickup from taking in oil at times?
Just one other think to check off...
BoostedAWD91
Danville,Pa
sean i have a few of the sending units i believe over at the garage if u wanna swap one over and see if it still comes on. Might be it if ur oil pressure was fine when the gauge worked
SleepinGVR4
Quoting 1990ggsxnj:
It has a small dent in it. Its just weird it doesn't come on unless the car is fully warmed up and i've been drivin it for like 15 mins.
fivestardsm
Middle, Michigan
+1 on checking everything stated above. I would start with the gauge, then if its still low, take the pan off and check it out. You might of had something come apart if you did a BSE. Also, I have seen the oil pick-ups come loose at the pump. This will only last for a while before both bolts fall out. If you did the ARP main studs and cut off the pick-up bracket, your in even worse shape. When that mod is done, the bolts fall out of the pick-up, and the entire thing falls into the oil pan. As for the oil pump, TOPLINE SUCK's for sure. 100 miles on mine in the GGSX!!
fivestardsm
Middle, Michigan
SleepinGVR4:
That is because the oil is thicker when it is cold and keeps more pressure. When it warms up and thins out, the pressure drops.
Wow I have exactly the same problem. Buying a gauge this weekend. If its low I guess I'll pull the pan, motor was supposedly rebuilt recently, and BSE was done, hopefully that didn't muck up anything.
