OEM Top Mounts. Front.
miller
Ireland
I recently installed new Top Mounts and new shocks, say about 6months ago with less than 500km on them. Front right mount is knocking bad, i dissasembled it and it seems like the sleeve in the top mount was rocking slightly. Re assembled and the knock is worse than before.
Is it just unlucky with a bad batch or is there brands to avoid? Or is there something else to watch out for on the Galants?
KiNgMaRtY
Corona, CA
If KYB still makes them, I would try to source some of those.
Most users have moved over to Coilovers and will use the Pillowball mounts. You can also install Pillowball mounts on the OEM tophats.
Imback
Suffolk,NY
There is a guy who just posted a set of tein camber plates new in box on the galant vr4 page on facebook. I have a set of new gabriel in a box at work as well.
miller
Ireland
Thanks lads, know which Facebook page that was? Trying to keep it OEM as much as possible though.
