yeti
So the car was running fine today, I went to change the valve cover gasket and decided to add PCV system back to stock.
Did BLT , Cleaned injectors ( with eBay battery powered device ) and put in new injector seals.
Did BLT and holding pressure
Go to restart and just get a bunch of cranking.
Tried bump starting down 6 blocks the car would turn on but if I hit the gas it would die immediately.
Only way I got back home was to remove the intake to PCV line and let that breathe ( I started removing all new stuff or anything Changed once it wouldn’t start
Check logs and getting -40f IAT, -74coolant temp / 38psi Boost
Well that’s not right.
I’ve gone over the car physically and can’t see anything I did wrong or forgot.
I’m thinking it’s either my ecu frying/ some type of short circuit / or other electrical issue.
The fact that my logs are reading these screwed numbers LOCKED at idle means something correct?
Getting a CEL for coolant temp sensor circuit malfunction - this couldn’t cause this correct?
