i am having a problem with a 7 bolt after i fully rebuilt motor and eliminted balance shafts. i blocks the front balance shaft oil holes and put plug in place of the shaft and i didnt have any oil being picked up after i started motor for a few minutes still didnt achieve any oil pressure? it didnt even get picked up so i pulled pan and removed the pick up tube and checked gasket and saw that there was oil under the gasket as if there was a leak maybe causing it maybe not to pick any up.also was wondering if maybe the stub shaft bolt backed off. any help would be greatly apreciated.
