No front bumper support?
So it just clicked that I don't have a front bumper support for #642. The cyber bumper was mounted fine without it, but from what I understand the USDM bumper won't mount without it. Is this correct? I wasn't sure since I've heard that you have to have one, yet its on the running list of items to completely eliminate.
steve
NJ
I thought Pivvay welded up some mounts to run no bumper support, just the cover. You need something to mount the cover to. /ubbthreads/images/graemlins/confused.gif
Thats what I thought. I'll have to look at it once the IC is in today. Hopefully I can fab something up without to much hassle.
NateCrisman
Blairstown, NJ
yeah, you need to rig up atleast 2, if not three small brackets to hold up the bumper cover if you want to completely remove the big metal support. The oem side brackets work fine, you just need to make two brackets that go to around the spot where the stock bumper support bolt on to the frame. Putting an additional one in the center keeps the cover from sagging in the middle.
SmoothCustomer
Lexington, KY
Right, it's the bolts behind the turn signals you would be losing. My bumper is only held to my car by 6 bolts and yours can be too if you rig something up for those 2 bolts. The 2 that are sort of underneath the headlights and the ones that bolt to the fenders are attached to the cover, not the bumper.
I don't suppose anyone has any pics of their brackets? Having trouble visualizing where I'm attaching to, since I never really had/saw the piece that I'm replacing.
GolfBall
Edmond, OK
hopefully you dont ever rear end somebody.... HAHAH....
no i take off the HEAVY front bumpers off all my "fast" cars.... i will take some good pics and do a write up when i take mine off but it will be about a week or two....
This won't be my "fast" car. Thats what rolling S13 chassis in my garage is for /ubbthreads/images/graemlins/hsugh.gif Normally I would prefer to have it since this is my daily, but since I don't have one and replacing doesn't seem to likely I guess I'm going without. I'll probably try to rig up something before the weekend. I'll post pics in my build thread if I do.
I've found that the heavier USDM bumper just transmits more force through it during an impact, which means bent items behind it rather than the bumper itself. I'd rather have a bent bumper than a bent unibody. In a bad wreck, you're probably screwed either way.
With the rust that it has on the frame rails and drivers side floor pans, I'll junk it if I get into a major accident anyway. Just wouldn't be worth salvaging.
