Newbie type fuse question
Driving along - everything fine.
Stop - shut car off
Get back in and Windows, Seatbelt, Sunroof, Heater fan, Clock do not work.
Everything else seems fine
Car still runs perfect.
Fuses under dash all seem fine
Fuses under hood in main box all seem fine.
What am I missing.
GVR4_1057
Brucetown VA
Find the fuse that controls the items that you are having problems with (like the sunroof) and replace the fuse and see if that helps. If not see if there is voltage at the fuse block. If not Work from the fusebox up toward the battery.
toybreaker
iconoclast
Check the big, bolt in fuses at the battery terminal for voltage on both sides. (It's easy to check, just put the voltmeter lead against the mounting bolt head.)
Then, check the bolt in alternator fuse in the front fuse box the same way.
Quoting toybreaker:
That was the baby.. thanks alot.
Loose connection from when I did my battery kill switch..
My car seldom breaks down - I just mess it up so it won't run... lol
