Newbie here with a kind of sad story.
Yokin9001
Member
Rancagua, cl
Hello! Since i was a kid i feel in love with Galants. i had plastic models, played with it in videogames etc... but i never had the chance to see a real vr4 (here are just "regular" galant).
Well years has passed and now i still can't find one to buy (btw im from south america). Sadly it seems that im never getting one since there aren't vr4' here and importing one here is next to impossible ( we have newer evos adn other goodies) due to way too high import taxes also is forbidden to import a car thats older than 10 years. So, the only thing i could do was buy a regular galant that for some reason is called the galant "super saloon" and that's strange because i could find any info on this trim. i know the car is the E32A chassis and it comes with a carburated 4g37 1800cc engine. So what i'm doing here if i don't have a vr4? well.. i came here cause you're my only chance to find parts and try to upgrade to at least to gsx standards.
Im going to be really grateful if you guys accept me here. i know that i have LOT to learn nut im really willing to do it. btw sorry if my english isn't as good as it should be.
Some pics of the car
Yokin9001
Member
Rancagua, cl
it's an 89 model (chassis code is E32A) the interior is the brown one also it comes with manual instead of auto (im pretty sure that 90% of galants here are automatic)
Yokin9001
Member
Rancagua, cl
yup. and that makes a little bit of a problem when finding parts. there are dsm models, japanese ones and ... Venezuelan.
For some reason parts aren't "tradeable" and most of the spare parts that the importers hace are the dsm ones and they don't fit my car (brakepads and others) i tried with the ones from venezuela but its useless.
so thats why im here : im trying to get the real origin of the car, part numbers and if it possible to do a clone of a vx or a viento (since i don't think i can put 4wd and 4ws to a fwd model),also i want to learn as much is possible about the car
bigandbad
Hamburg, Germany
Hi, if you give me your VIN I could do a quick search at our european ASA (Mitsubishi programm) to check where it was made for...
The 1.8 sedan was a very popular modell in Europe, your white/brown combo was one of the most sold. The 1.8 wasn't sold here as an A/T, only 5-Speed M/T...
OldHairyBastard
Northern Chicagoland Area
If you can find a front wheel drive Eclipse GSX turbo you can swap over the whole drive line and wiring harness. You will have to use all of the motor mounts from the Eclipse and the front spindles, A arms, axles, brakes... everything. You will need to swap the wiring under the dash for the MPI relay and add a fuel tank from and EFI Galant or make your tank work with the proper fuel sending unit and high pressure fuel pump. I'm sure there are a few more wiring tricks to overcome but that would do it. It might be easier to start with a Fuel injected model if you can find one or see what you can do with the Eclipse parts.
