Need input on some cylinders
Spyder
Des Moines, Iowa
I am tearing into the engine of the car I bought from Asmo.
He said the engine was blown because the head gasket was leaking and the previous owner put stop leak in the coolant. The stop leak got into the cylinders and scored the sides. He had it bored over .20 and used Mitsubishi parts to rebuild it. The head is trashed and that was addressed earlier.
I have a link to pictures I took of the cylinders and one picture of a rod bearing with damage. I need some help diagnosing and trying to see if I am fucked on the block or not.
Under each picture is the file name and it designates which cylinder it is and which wall you are looking at. For instance, Cyl_1_Intake would be Cylinder 1, intake side wall. Etc.
You can not feel the marks in the cylinder walls, just see them.
The rod bearing has pitting like it started coming apart. I have never seen that before.
If anyone could give me a hand I would appreciate it.
Link Here. Photos
rdomeck
Indianapolis, In.
I would run a hone thru them and check with a dial bore gauge. Just run the hone enough to take away that scoring. That is if you really can't feel it with your finger nail!
What kind of power was this thing making before failure? What is your goal for this engine? What do the pistons look like, are they grooved? I'd run up to 300 CHP with just a simple hone job. Anything more and you might have ring sealing issues. I'd like to see what others have to say though. You need a rod though.
Oh and if you need I can see about locating a block up here if you need.
Spyder
Des Moines, Iowa
why do I need a rod?
The power is not much. I don't know numbers at all but probably not much over stock. It has a small 16g. That's about it.
The picture of the rod has the bearings installed, the damage is on the bearings.
GEDengineering
Miami, Fl
Measure the bore and check it for tapper, if it has more that 0.1 mm of tapper it will have to be bored over again. Also check the piston wall to piston clearance those scores may be from piston slap due to improper claerance. if you need the factory service manual just let me know I can provide you the link and it will describe all the info i dicussed above.
GED Engineering
Quoting Spyder:
Rod looks burnt. If it's heavily discolored it may be out of round/tapered or possibly fatigued. Being a low power build you might be ok, but there is a chance. Like mentioned, measure out the cylinder and check it's condition. You might be able to run it after a good hone.
