my car shuts off
so today i didnt use the a/c at all and the rpm stayed normal and my car didnt shut off but when i turned that sh*t on and went fast and let my rpm drop it shut off
i also tryed it again without a/c and it wanted to shut off /ubbthreads/images/graemlins/dunno.gif
broxma
San Antonio Tx
Cars tend to die due to over lean conditions so check for an intake leak or leak past the MAF. Also if you are venting you stock BOV to atmosphere, stab yourself in the eye, and then with your good eye, reconnect it.
/brox
Diego
When you try to turn the car over, you might hear a "click,click" coming from your passenger floor board right above the kick panel, that's where the ECU hides out and if that click is there, its time to open it up and check the damage, mostly a loose or corrosion set in and you have leaky caps....
If that's the case get a hold Terry Posten its about 50 bucks, get a ZIF socket and then your set up for a keydriver or ECMlink
my cuzin checked the ecu its fine some guys in this forum told me to check for a intake leak or boots leak?????
Diego
" Boost " leak. Yes check that out, check your maf wires for fraying also to be causing a short. Make sure all hoses are tight and sealed, as to have a closed loop pressure and no leaks, allowing to much air to hit the maf or causing a surge to kill the maf
yeah your not a bad guy lol if you where part of that whole grammer thing i apoligize.
it really piss me off because the one who posted that was my cousin so i was backing him up
Diego
If you want to send me a flick on my cell
7123894004. Focus on filming what's important to the issue and where you hear, feel, etc... I will help to best abilities w/o realistically being there
alright ill try to do it tmorrow because i have a iphone 3g and that sh*t dosent record
soo ill try to record it after work tmorrow
IPhone 3g records, you just need to plug it into a computer, go to apple's website, and download the ugrade. Then you go to the app store, grab you a video recorder app, and viola. Your all set.
