MMCD Help
James
Port richey Florida
Im browsing google as we speak, but figured posting would be helpful also.
I got MMCD on the palm and it opens up fine. when i plug it in to my car the reading dont change. all zeros or blanks across the board,as if its not reading anything. any suggestions?
PalmIIIc is the palm im using, everything purchased from a member on here
pot
Fayetteville, NC
Sounds like you may just need to "uncheck" the little box on the middle-right of the screen. I think its "pause."
James
Port richey Florida
no, i have enerything i want to log highlighted, when i unclick pause, it cycles everything at the bottle left of the screen before repausing automaticly
pot
Fayetteville, NC
Then what screen located top right are you on out of the 4? Give either screen shot 1 or 2 a try....
James
Port richey Florida
its currently on screen1, i have the items i want to read highlighted. when i unpause, the dashes to the right of the name (rpm,tps,o2 ect) stay as dashes, its not reading.
pot
Fayetteville, NC
I understand what your throwing down. How about tapping the items left of the dashes or the dash itself?
James
Port richey Florida
nothing on both both accounts.
When i just went to option and 'test" it says "serial comm error"
did i maybe get a bad data cord?
pot
Fayetteville, NC
Thats about the only conclusion left to draw -especially w/ my limited knowledge. There are several FAQ's circulating the net on MMcd as well as plenty of knowledge here. Be patient, soon enough other board members will chime in.
James
Port richey Florida
i found the correct speed MMCD should be set at under preferences, and my speed was wrong. i changed it to the correct speed and still no luck.
still "serial comm error'
mitsuturbo
Near Seattle, Washington
You can make a new cable for about $3. It's not difficult, or time consuming. The trip to radio shack will probably take longer than assembly.
If you need a diagram, i may be able to dig one up at home.
I believe i may still have a pocktlogger name and regcode that i wouldn't mind sharing as well. I believe you can DL the software for free. You'd have to rename your palm "sunfighter" and iirc the code is 168613152, but i'll have to double check. I think it's still written in sharpie under one of my doors in 1411/2000.
James
Port richey Florida
Still waiting to hear back from the user I purchased the setup from, till then illkist be reading about the error till my eyes bleed.
Off topic- my car is a 90 galang gsx, with what's assumed to be a 92 tsi motor and ECU. (the ECU is for sure 92 tsi)
Could this make a difference? I'm sure my diagnostics port is still 90gsx
James
Port richey Florida
In my searching I found once incident where the guy said something about a nonturbo o2 sensor wiring, when he put in the turbo o2 sensor wiring it fixed his issue, is why I'm asking.
I know that's a stretch, but yea.
mitsuturbo
Quoting James:
I'd think if you converted a GSX to a turbo setup, you would have swapped in a VR4 wiring harness. If you're getting codes and still have a one wire o2 sensor, i suspect that as a likely candidate. Also, what did you do about the knock sensor? Without a knock sensor, you'll get a code as well. Also, the ECU wont give you any timing.
James
Port richey Florida
I didn't do the swap, I purchased it this way, I know the ECU is out of a 92 talon tsi, the motor/trans I can't say for sure
And I'm not currently throwing any CELs.
ejc
Active member
Puerto Rico
I have a similar problem sometimes and its the connection between the cable and the Palm. On mine I remove the pause and move the cable until I have a connection. Might not be your problem but its easy to try it out!
downingtown, pa
kinda new to the palm logger stuff but i got a snapon modis with the aldl12 adaptor and couldent connect it ended up bein pin 10 had no signal from i wanna say pin 2 on ecu it was a loose pin fixed that and connects and actuates sensors fine now. found the pinouts on ecmlink website, of u need a link im shure i can find it again. worth a shot. 1 12 and 10 are key 1 and 12 are pulsed 12v and ground dont remember which and 10 is data in and out of ecm aprox 4.5v. lemme know if u find anything.
