miscellaneous mounting bolts
paul j
Lone Tree, CO
Rear roll stopper coupler bolt M10 x 110 tapered cone end
Front roll stopper coupler bolt M10 x 75 flange and locking flange nut
Front engine mount bolts at firewall side of the mount M10 x 73 washer assembled - two of these.
I may cut down some new 75mm ones for the front mount. I can not believe I have misplaced these bolts. and the couplers.
paul j
Lone Tree, CO
No pictures. Unless you have a parts book.
1st one goes through rear stopper rubber bushing on body and connects to arm that goes to block.
2nd one goes through front stopper rubber bushing on body and connects to arm that goes to block.
3rd ones hold front mounting bracket onto block. The left side of the bracket has studs the right side takes the bolts.
