LED dash questions.
Scientist
Roseau/Dominica
Anyone tried installing LEDs in the dash? Know what size LEds to use?
Rausch
Cleveland, OH
Man if that could get set up to flip between the white, and the amber color....That would be hot. As much as I like the green....The white looks very nice.
Terry Posten
Davenport, Iowa USA
With the dual color setup in the USDM models, as long as the LEDs have the "flood" pattern, should be doable.
I will discuss with my cousin tomorrow night and see if the dimming could also still work.
powerplay
Norwell, MA
I have changed all of my bulbs to red LEDs in the cluster. The switch nows works between red and orange. It is very easy to do. I changed the blubs in the dash switches/indicators as well. That is more difficult as some of the blubs are very small. You can't use just regular plugin LEDs, so you have to take the LEDs apart and solder a resistor and LED in place in the switch. I got mine from Super Bright. I bought a bunch of different sizes, but I believe the 74R works for the small ones (dash) and the WLED-R4 for the big ones (cluster)
ktmrider
Tempe, AZ
I like the look but agree it would be tiring on the eyes for extended night driving.
High kit price but sounds like the locals have figured out the DIY for a much nicer price.
DR1665
Iowa City, IA
DSMtuners link - Guy got his info from azdave, who is the king of LEDs. Search him out on HIDplanet and you'll see.
Dave has something like 5000 SMT LEDs hand soldered into custom circuit boards in the tail lights of his 2G Eclipse, but says the trick is flexible LED strips for the gauges.
I know in my dash all the led lights have a green plastic type sleave over them. it is easily removed this way you can change to whatever colour you like! /ubbthreads/images/graemlins/wink.gif
So if do a LED conversion how well does the dimmer work? Are you still able to dim the gauge cluster?
I have a spare VR-4 cluster in the garage if you need one for bench testing. Would I get a set of LEDs for loaning it out? /ubbthreads/images/graemlins/grin.gif
-Josh
I have 2 spare clusers(no vr4 though), if they would get a set of Leds, you may use them both /ubbthreads/images/graemlins/grin.gif
Alright I would like to do this mod. The thing is I'm not too sure which WLED to order from SuperbrightLEDs.com.. I was thinking the w5 led since it distributes light to the sides as well as straight forward.. They cost twice as much as the W4's though.. Does it look good with the w4's even though the light is directed forward? I'm worried that you will be able to see lighter spots on the cluster from where the lights are at than where they're not at.. /ubbthreads/images/graemlins/dunno.gif
I have ordered some LED's from www.superbrightleds.com I ended up getting 6 green WLED-X5's and 6 blue WLED-X5's for the gauge cluster. I also ordered 6 green high power #74 LED lights for the climate controls and ashtray area. I think any smaller WLED from superbrightleds will work in the gauge cluster.
