Leaking Capacitors? and other ecu issues.
Okayplayer
Denver, CO
I finally took out my ECU after having multiple issues with 1968. I opened up the ECU to check out the caps and found this. It looks like one of the caps were replaced by someone who wasn't very good at it. I also see some other areas around the caps that look like damage. So for the spark chasers, please give me an idea of what this type of symptoms this damage may cause, and it my board good enough to run and get the caps replaced?
Is this a salvageable board? Does it cause other things to burn out or malfunction?
Also the number on front of the ecu is E2T34463. So it appears that this is a is a 1G FWD California ECU! WTF!?!?! What does this mean as far as how the car should run?
Edit: It's a 90 at that! So is there any sensors that don't properly talk to the ecu? I have VR4 sensors, not 90...
notice how 2 of the caps are melted together...
Message Terry Posten and ask him, he is our resident re-capper. He will tell you that he needs to look at the board to see if it is ok. Even if it looks okoay, you will only know for sure when you get that melted stuff out of there and try to run the car with it.
Okayplayer
Denver, CO
I'm thinking I need a new ecu. I am not sure of the parameters set on a '90 ecu, but I know there are some differences when it comes to sensors on the throttle body and what not. This car has always had problems with idling, not it does not want to boost with a good turbo on it. I'm wondering if all this can be related to a bad ecu in the car. It's not even eprom.
FlyingEagle
THE Ottawa
What is the MD #, you are close to the FWD DSM ECU's I have listed.
Yes, the car will run with that ECU but pins 6 + 14 were swapped if it is a 90 board and 91 sensors were used.
What harness style do your TB sensors have - plug at each sensor or pigtail to a plug?
Okayplayer
Denver, CO
The number is MD128623. There are no pigtails just the standard harness
TRBODSM
Northglenn, CO
I know someone that can repair ecu's and has EPROM ecu's also. PM me and I'll give you his number. He lives in Longmont.
Okayplayer
Denver, CO
I still want to know if this ecu that I have now will run my car properly... I will check to see if the wires are swapped around going to the ecu.
luis84one
lynwood, ca
did this ECU work for you? i havee the same ecu and i want to swap it with the bad ecu on my 91 Gvr4
