Leaking axle seals
Hksvr4wd
Member
NY
Replace both left and right axle seals with OEM parts. MD719710 driver's side and MD707184 passenger side. Both are leaking, can it be the wrong size axles?
acn
Murray, UT
I had this issue not too long ago. Bought two brand new OEM axle seals and the passenger started leaking after replacement. I realized I had pushed it in too far in the trans housing and it wasn't sealing on the axle. I don't think there is a stop for the seal on the passenger side. I bought a new seal and was careful about install depth and it seems to be fine. I think there is something that stops the seal on the driver's side, so not sure what the issue is there. This is all off the top of my head. I think there are other threads about this same issue.
