lc1 install
jnava
Arlington, Tx
I hooked it up and did the free air calibration and installed the analog g4 gauge. I haven't soldered the brown wire into the ecu yet since I need to verify pin 4 is the correct one. The how to section links are gone and I'm hoping that the information given is correct. GVR4 ecus are the same as the 1g dms ecus? If so, then pin 4 is a go.
jnava
Arlington, Tx
Another question, what is the best tool to convert a db9 to usb. My laptop doesn't have a serial line and I hope to use the software to adjust the voltage on the yellow wire.
I just installed my LC-1, and used pin 15 for the input to the ECU. Reason being, if you use pin 4, your will loose the factory O2 and will have to simulate the narrowband with the LC-1. This isn't a bad thing, but personally I'd keep the factory O2 for error checking if you aren't going to be utilizing all the inputs. I would use pins 15 or 16. If using pin 15, you will likely have to insert a pin since the EGR curcuit isn't present in most VR4s.
raptorWagon
Oak Harbor, WA
Quoting prove_it:
ECMlink Recommendation page
I would read through this. All you need to know about the conversion connectors.
Also look through their site for your wiring needs.
Keyspan is the best! In my experience with the cheap ones as well, they don't work for sh*t, I was just looking for something cheap so I didn't have to keep switching my keyspan from one car to the next.
jnava
Arlington, Tx
Looked at the ecu and soldered in pin #4. Changed ecmlink pin assignment and added to captured values and it's working great. I'm doing narrow band sim. Thanks for the right directions, the links provided by some of you help out. Thanks and I will have to get a keyspan to change the lc1's yellow analog output so the gauge can work.
Quoting GSTwithPSI:
There should be a pin present as well as the wiring to the engine bay. There is a wide connector taped back near the washer bottle that is for the egr. I used it to wire up my BOV control through ecmlinks egr output.
Pretty sure the wiring is all there even on the federal cars.
The wiring throughout the car is there, but #14 in the 24 pin connector plug is not present on Federal cars.
I thought the EGR temp sensor is pin 15 and the egr solenoid is pin 53. /ubbthreads/images/graemlins/confused.gif
