Koyo Radiator
KiNgMaRtY
Corona, CA
While working on my idle issue last night, I noticed steam coming out of my radiator. I looked closer and the fins were soaked with fluid on the drivers size. So time for a new radiator.
Reading through some threads, it appears that the Koyo Evo III radiator fits the VR-4. just needing some spacers on the bottom. My questions are: are the Evo 1-3 radiators all the same as I see them listed Evo 1-3? Do I need to weld in a bung for the sensor?
Thank you. I assume I may be needing some slim fans as well as the clearance is already tight with the OEM like radiator.
kama1
q.c. philippines
my friend has an evo3 koyo rad and im using a generic alum/ebay evo3 both in galants.spacers at the bottom and a slim fan is a must.
as for the sensor you can either weld a bung on it or use a radiator hose adaptor.
spooling92vr4
long island, NY
I just did this, I bought a hose adapter but than decided to weld a bung into the rad. other than that it was a bolt in affair, If you go with the koyo remember you also have to purchase a cap seperately as our stock cap wont fit.. the koyo caps another 25 bucks.
