Knock sensor help
James
Port richey Florida
For starters the problem is that my car rewads 40+ counts of knock at ANY AMOUNT OF THROTTLE. Sitting in my drive way if its in Neutral and i give it a couple of revs i get 40 counts of knock.,
I replaced my knock sensor with a known working one, though mine looked good when i took it out. whats next?
note- previous owner had to have wired the sensor in since its a non turbo harness. (correct?).
EHmotorsports
Beaverton
Never trust another persons wiring. Unless if it's working properly. I would start by checking the wires from the knock sensor to the ecu. Also take a paper clip and do a drag test on the pins.(battery disconnected) and make sure they have proper drag to make a good connection.
James
Port richey Florida
I would think if the wiring was bad I would either get a cel for the sensor, or the readings would be more random.
I visually checked the wiring and it looks good. I'll physically check it tomorrow.
My gut wants to say its not real knock but it's screwing with everything else. When I hold the throttle at 1k to try and level out the fuel trim i get 35 degrees of timing advance.
ktmrider
Tempe, AZ
Sensor is super sensitive to torque, ie over-tightening. Barely over hand-tight IIRC, 7ft/lb. Will cause crazy knock like described if too tight.
Also heard of people shimming the KS with copper washers, helps drop some phantom frequencies.
Xcelerate
Active member
North jersey
Eighther bad sensor or too advance timing. Check the wire to terminal also make sure it's on the right pin. And make sure he use a sheilded wire coz regular wire will bleed out and pick up noise from the chassis.
