just installed goodies.
MRmeeTooxD
chicago, illinois
Hey guys just need a bit of help. Just got a vrsf fmic, 16g, intake along with new gaskets on throttle body and biss screw and half size radiator and brand spanking new tranny along with t-case. The car runs awesome on stock pressure. I go on express way and push the pedal to medal, and man steady at 9psi. After a small jolt in traffic, push in clutch and start releasing again on first my car starts to stay idling high at 2000rpm. Then when I engage in clutch to first gear, I start releasing the clutch smoothly its start to go down but then rises on its own..
so any ideas?
MRmeeTooxD
chicago, illinois
Lol ah ah yea it freaks me out... but yea I don't have any noise besides when I start it early morning the alternator belt...other than that nope..
Kinda hard to follow without grammar. Are you saying the RPMs rise on their own?
If so I'd look for intake side leaks. Boost leak test is in order. Also make sure your BISS screw is adjusted properly. Another thing, low coolant can cause the FIAV to get funny, be sure the coolant is properly bled and full.
