ISO 5 lug swap
Wolf194
Member
Ukiah
My stock 4 lug driver rear wheel bearing is starting to show signs of needing replacing. That’s my reason to start looking for a parts car 1g to do a 5 lug swap. Any chance someone in California has leads or parts you’re willing to sell. Also out of California I’d be willing to pay shipping.
Jorenas
New member
new york
Makes sense to start looking for a 1G parts car if you’re already dealing with a rear wheel hub bearing that’s on its way out. A complete donor could give you everything you need for the 5-lug conversion and save you from hunting down individual pieces. I’d especially try to find a complete rear setup with the hubs, knuckles, bearings, and associated hardware still together, since that makes the swap much easier and gives you a chance to inspect the Precision spindle bearings before installing everything.
nazagalant1993
buenos aires , argentina
You can repair them. At Rockauto you can find seals and bearings to do the job. There's a video from Jafromobile that shows a bit of the process. It takes time and some specific tools.
Wolf194
Member
Ukiah
RedTwo
New Zealand
34068 MB393807 DUST SEAL,RR AXLE SHAFT,INR
33103 MB290175 BEARING, RR AXLE SHAFT [BALL,16X58]
33109 MB393803 COVER, RR AXLE SHAFT OUTER
33108 MB290428 COVER, RR AXLE SHAFT INNER
33105 MB569972 BEARING,RR AXLE SHAFT,OTR [BALL,72X17-35]
33138 --- ROTOR, RR AXLE SHAFT (ABS sensor gear, reuse)
