Installed LC-1 and now wont start!
rdomeck
Indianapolis, In.
I installed an Innovate LC-1 on a good running car and now it just spits and sputters when I try and start it. It acts like its out of fuel, but I have good pressure. I installed it using the front O2 input and used the brown output from the LC-1. I use a Mac so I don't have a way of hooking up the DB-9 connector to program the LC-1. If I understand correctly the brown output is a 0-5 volt and shouldn't need programming to be used? I also haven't figured out how to show the Air/fuel ratio in the logged values?
I have now noticed that I can log and display the LC-1 WB. But it is light gray which indicates to me that I don't have something set right. Still seems like this thing would start? It just acts like it's out of fuel, but I have 67 miles on a fill up and I have fuel pressure at the regulator! I have pulled the plugs and they don't look wet.
What id going on with this thing?
As always, thanks for the help!
gramkrakr89
Bunker Hill, WV
ECMlink?
brown output is the wideband 0-5V output, used for logging or guages
the yellow output is programmed 0-1v for narrowband emulation i think
you need to change your wideband input to "FrontO2" and enable narrowband simulation in order for that to work, i think
rdomeck
Indianapolis, In.
I have done the things listed above. It tries to start, but acts like it's out of fuel. I have fuel and spark. This one is making me feel really dumb. I may try going back to the factory sensor and see if I can make it run. I would then know that I have a O2 sensor issue and not something else that just happened at the time I installed the WB!
jepherz
KC, Missouri
I could be wrong, but I'm wondering if the o2 sensor feedback is even taking place on a cold crank/start. I know you said the spark plugs don't seem wet, but can you ensure us that you haven't broken the coolant sensor wiring on the thermostat while digging around there? Maybe those wires are damaged and it's adding way too much fuel.
