Ideas for new battery/relocate
mrbonnell
Active member
Fort Myers, FL
/ubbthreads/images/graemlins/laugh.gif Hey guys, Im in the market for a new battery. Ive done some research on some batteries already but before I jump I though I would ask a few questions.
The idea of relocation came to mind and I wanted to know generally how you guys like it, and went about your relocation project. If I do relocate it I would like it to be in the trunk.
I was also wondering what kind of batteries some you use. I have a 13 pound battery in right now its about 6" in height, 3" in width and 6.5" in length. I like the size and weight of it due to being light.
The reason I want to move it is because where my battery sits is pretty tight but due to the small size I can manage with where it is now. Pic attached for you guys to get an idea of where its at. Thanks for the help
PreskitVR4
Prescott, Northern AZ
The problem with relocating, is the cutoff switch that is required if you ever plan on dragracing. Also, our charging systems are not known for durability. Adding another 10 ft of line loss to the back of the car is prob not best. I know that statement will start a firestorm of "I've been doing it for years" but from a battery guy's POV it's not best case scenario. I have a group 51R Optima on a DSM batt tray nxt to the pass side strut tower. I like it, no cutoff required, and it moves the weight toward the center of the car.
mrbonnell
Active member
Fort Myers, FL
Was that the stock battery location on the Galants? Ive seen some cars with batteries in that location and I wouldnt mind putting mine there.
And yes I do plan on preping a track car someday. I guess another question I is are the little half batteries as reliable as the the regular sized batteries?
PreskitVR4
Stock location is behind headlight. Anything outside of automotive BCI group sizes can be very unreliable. There is Braille, Odessey, a few others, they either offer low CCA, or are crammed full of additives that make their chemistry unstable.
mrbonnell
Active member
Fort Myers, FL
Im unfamiliar with the abbreviation BCI, what might that stand for? So what might you suggest? I really dont have any room for a stock battery seeing as my intake pipe is so long and massive. lol
beaner
b'ham, mi
What is the point of moving the battery to the trunk? It's like moving the fuse box to the glove box. No part of the mod makes sense to me.
brisvr4
brisbane australia
I put mine directly below the stock position to free up room for my intake.
It will probably only work there if you have short route piping though.
Noobsauce
Beaverton, Oregon
Some move the battery to the back for weight distribution. In an attempt to make the car have more of a 50/50 weight distribution. Makes the car more predictible in the corners.
Most others do it for "cuss racecar" status and for looks.
BluFalcon
Wichita, KS
I cut out a flat plate that bolts to 2 of the 3 MAS mounting points. The stamped steel battery tray for the Odyssey PC925 then bolts to this plate, with a third 90 degree bracket that I added to the battery tray to allow it to bolt into the 3rd MAS mount point. Click on the link, and it'll show what I did a little better than I can explain. The nice thing about this, is that you don't have to cut or alter the positive battery terminal or ground lead, and it allows you to install a straight MAS intake pipe.
rdomeck
Indianapolis, In.
Don't rule out the battery in the trunk......A lot of cars come this way from the factory. Porsche and BMW to name a few! leaves room for other stuff in the engine bay.
mrbonnell
Active member
Fort Myers, FL
Thanks for the insight blufalcon, I see better what you have done. Im torn now between your set up seeing as it is quit simple and a rear mount. a good friend of mine is a bmw tech and him I would be able to wire it to the trunk. Pics to come thanks for the help.
alansupra94
Wayne,NJ
Quoting PreskitVR4:
I basically bit the bullet and redid my whole entire electrical charging system. I installed an old durable rebuilt GM CS130 250AMP alternator, 250AMP breaker, distributors, new fuse box (to replace that ugly fuse holder on the battery terminal) and then 0 gauges all around ending at the yellow top Optima. Got tired of the sh*t stock alternator and the crap small wiring. Electrical system is now fantastic (with the solar panels /ubbthreads/images/graemlins/devil.gif)
i usually put the battery in the trunk.. get a battery box and hold-down kit from auto zone... weld 2 washers to the floor so you can loop the j hooks on each side of the box and make an aluminum bracket from each side of the box to hold the battery down... you usually have to notch the plastic box to get the bracket to fit snug... other than that you only need to make 2 slits in the trunk carpet for the washers to poke through and the end result looks nice if you take your time and do it right..
belize1334
Bozeman, MT
I got a JMFab kit for 1G dsm for the PC925. They say it doesn't fit, but it was really easy to adapt. Just get a piece of aluminum strap and use it to extend the lateral bracket up to the attachment point on the side of the strut-tower.
