I think this car hates me
Steve885
Concord ca
Man I'm having such a hard time with idle...ready to tear my hair out. It's never consistent..
1 if I warm it to 150 + it surges after a mile or two at every light
2 if I don't warm it up it surges out of the drive way when the clutch is in
3 some time the idle dips so low at stops the oil light come on for a sec or it dyes
4 yesterday the idle went up to 2000 rps and wouldn't come down till the engine cooled for a hour
Any one experience this... Will. Link controll idle in some way
dsm10o0
San Jose CA
I had the same problem. Pretty sure you'll need a new or good condition fast idle air valve. Or you can buy the block off plate and you wont have to worry about it.
BpuVR4
Chicago
since we're on the subject, when adjusting the biss screw, do you guys generally set it to the minimum turn as to it won't stall the motor? I've realized that even a 1/4 turn of hte biss (both leads grounded) affect how the car pulls. my isc is left unplugged by the way, and it holds idle just fine.
FlyingEagle
THE Ottawa
Do not forget to check for a ground return at the idle stop switch, located top side/back on the TB. There is a little bar that attaches the TB to the top rear stud for a return path for ground. Computer uses this at many instances, but solve your idle issues and at the same time check this.
mikus
Aurora IL
If the last line means you're considering ECMlink, do it. you'll never look back. Plus you'll sort out idle easy.
