broke down
Someone please help me identify the purpose and routing of these two wires. Right now I'm knee deep in fixing all of the &^%%#*(# jacked up splices/taped-up/scotch locked connections on my project. I came across these two wires that have been cut/spliced into aftermarket wires. I cannot find the other side of the factory wire where the cut was made.
Here is the first one. The pink wire comes of of the black connector, then goes into an aftermarket wire with a terminal on the end, which isn't important, really. Am I correct in thinking that this is the diagnostic socket, on the fuse panel? There are eight male terminals in the socket. Where does the pink wire run to?
The next photos show the largest connector for the ecu. There is a green wire with red stripe that comes out into an aftermarket wire, but I cant find where it goes to either. From the back of the plug, it is the bottom row, third wire from the left. I cannot find where the other side of the cut wire is in the harness. Does it go to another nearby plug, or up into the big bulk wire harness, or what?
I would appreciate any help on this matter guys. thanks.
