HVAC controls
AWDnoobie
Alberta, Canada
I have a few questions about the slide levers under the dials. I know the one on the left is for fresh air or recirculation, but what is the one on the right for? It has a L and R. And last question, has anyone moved the controls to where the radio is located? If so was there anything to look out for the cables or some wiring that I havent seen yet(dash is still in place) The reason is, id like to put the deck up a bit higher due to a flip out screen.
cspetros
Port Norfolk, VA
It's a volume allocation control lever. It directs air in accord with the selection you make. If you pick "L", it directs a higher volume of air to the left side of the vehicle cabin. The right side still gets air, but not as much.
Hope this makes sense. /ubbthreads/images/graemlins/smile.gif
AWDnoobie
Alberta, Canada
Thats a cool thing to have, but since it really doesnt do much, those two levers are now going to dissappear. Only other thing is if anyone has moved the dial controls down to the stereo location?
