How to search for harness?
alik
Boston, MA
A section of my harness (namely right near the water neck) has pretty much disintegrated. I stopped by a couple of local junkers, but they don't have any DSMs.
Question is, how do I search on car-part.com for a piece of harness?
(That's the motley crew of sensor connectors near the water neck, including the O2 sensor. They're all busted. I can either source out the connectors one-by-one, or graft a piece of harness.)
Thanks!
Struc
Oconomowoc, WI
It happens to all of them. Too much heat.
I pulled my harness apart all the way back to behind the intake manifold, near the firewall, and soldered new wires there and rebuilt the harness.
tektic
ronkonkoma, ny
No one is going to stock part of a wire harness.
You can get new spade conectors and solder them on with as much wire as you need to replace the burnt piece. The only thing on this section is the o2 sensor and the various temp sensors.
Most time I've had problems in this area it was just broken ends. The wires inside the brittle plastic cover was usually fine.
