HLA Pressure Regulator Question
Bonecollector
Member
In The Woods, AZ
So... I have a Piston and Spring style "Lash Adjuster Oil Pressure Valve" (see attached photo for parts diagram).
Have any of you use one, and tested the pressure they are regulated at?
Bstiles
Member
Indianapolis
Is this the factory hla or the evo hla? Iirc, the evo hla limits pressure to 14psi and dumps the rest of the oil into the head. The kiggly hla limits to 14psi but doesn't overflow the extra into the head, it keeps it in the pan.
Dashnizzle
Active member
Great Falls, MT
i took my stock one out and replaced with Kiggly for the reason mentioned above. Pretty sure you need one either way but dont quote me
