I have a 1g 4g63t 6bolt, the car won't turn over after i installed the transmission. The tranny was from a 1g eclipse for my galant vr4, I will post up the part number asap ended up also putting in the transfer case from the eclipse also. I can hear the starter kicks out and spins, had it tested. The starter could be not contacting the flywheel. Or the sound is turnover then a jamming noise /ubbthreads/images/graemlins/uhh.gif. yet i can crank it by hand np. which is the same flywheel that i had with the previous tranny and it worked fine. I haven't gotten a chance to look at the flywheel while someone turns the key so i will get back with more details. the only thing that i have changed is the pressure plate and clutch combination because the last clutch cracked ( pos aftermarket )and the pressure plate was warped with the old tranny.I had a stage two pressure plate laying around and a stock clutch disk that i threw in for now. Could that combo be causing it not to turn over? so yea Help.
/ubbthreads/images/graemlins/confused.gif
My goal is to simply get this car to run /ubbthreads/images/graemlins/banghead.gif. Thanks in advance.
I dont know why this poll is here lol /ubbthreads/images/graemlins/dunno.gif
Stay tuned for a video...i will prob add another thread with just the video.
