HELP!!!! 15 MPG's??
what in gods name could cause my car to get only 15 MPG's? its on stock injectors and stock ecu??? I run 93 so im confused..
Quoting preach:
check your 02 sensor make sure its toggling.
Jesse
Ill check the 02, soon as i figure out how lol
it has a fresh tune up on it, motor only has 3k, and my right foot is light these days lol
ktmrider
Tempe, AZ
O2 and FPR are the likely causes.
FPR will cause it to run incredibly rich at idle then lean under boost.
Did you ever fix the described single injector issue?!? This could be causing a problem, the other 3 could be dumping fuel to compensate...
Yes i fixed the issue, i replaced all 4 of the wrong injectors with the correct 5 speed AWD ones
