Grey 1991 VR4 in local u-pull it yard.....what should I try to get?
ou812
Member
Klamath Falls, OR
Hey all....went to the local u-pull it yard last Saturday, and lo and behold....a 1991 Galant VR4. The dash plaque was gone, so I do not know the number of the car. They must have just gotten it, as very little has been removed from the car. It looked like a passenger side guardrail type wreck, with the passenger side with slight to medium damage. I believe that its complete, or nearly.
What should I get off the car, and if so, does anyone need anything? I will likely go there this Saturday and get some pics while I am there....might take the time to get some parts too, if I have time...
thanks,
Jeff
thomcasey
Indianapolis, IN
windshield trim, shift cables with mounting plate, heater vents that run form heater cor to under front seats (they are under the console). All those are for me. AS for anything else, grab what you can !!!
ou812
Member
Klamath Falls, OR
I will do my best on that stuff.....dumb question....how to remove the windshield trim? Not sure if its in decent shape or not....
The other stuff should be pretty easy to pick...
mitsuturbo
Near Seattle, Washington
On the rear window, i need the left side trim. Mine has a ding in it. Of course, i only want it if it's in good shape with no scratches/dents. I also want the trim piece on the trunk. The black one that goes above the tails. I want the tail lights if they are in good shape.. no scuffs or cracks whatsoever. If the center piece for the tails isn't cracked in the corners, i want that as well. Basically, the entire rear tail and trim sections, i want if they're good.
coyotes
Seattle, WA
grab the valve cover if it's not cracked, the doglegs, the bumper if it's in good shape. just all the misc. stuff that you know would sell.
LIV4PSI
O-H-I-O
Dog legs, A pillars, engine harness, fuel tank and sending unit, dual piston calipers, fog lights, center console lid, fog light switch, thermostat housing, 344 front bracket, turbo/intercooler with piping, injectors, CAS, valve cover, throttle body and ECU.
All that stuff will sell easily and I'm sure you could make decent money
Quoting ou812:
Get the VIN.
ou812
Member
Klamath Falls, OR
I am not 100% sure its Kensington Grey, or black....was about dark when I saw it, and I didnt have a light. One or the other, and not sure if the bumper is nice or not. Pretty sure it hasnt been cut but will have to check it out.
I will also get the VIN....
ktmrider
Tempe, AZ
Quoting LIV4PSI:
Perfect list.
Wookalar
Arizona USSA
I'm not calling dibs however suggesting that the pedal box and HVAC boxes are galant specific and can be refurbished/rebuilt. Access to the hvac system anchor bolts requires dash removal though. I think it's a good idea to keep those pieces out of the crusher if you have the time to pull it all out. Perhaps think about also saving the turn signal stalk assembly if it isn't beat up, and that's a third the way to the steering column coming out for access to the pedal box. /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/grin.gif
As far as I know dsm pedal box are not interchangeable with the e39a.
ou812
Member
Klamath Falls, OR
thanks....lots of great ideas here. I will check it out closer this weekend, or maybe Friday if I take the day off. I got a local buddy that wants the tranny so might be a bit of a decent sized pick on the car...lol
92_talon_awd
Knoxville, TN
If you get the resistor for the fan switch I'll buy it, my fan only blows on the two highest settings
Mr_Fielgood
Morgan Hill, CA
Dibs on the rear steering rack assembly, sun roof trim moulding, radio antenna assembly, shift knob (if it's oem), cylinder head
All if decent condition & rust free.
Request to send photos upon pm?
thruarod
Ogdensburg NJ
I would love a 4ws front rack, reservior, and a non peeling up dashboard. But UPS would want a firstborn son to ship those to NJ.
But the dimmer switch wouldnt be so bad if its there.
ktmrider
Tempe, AZ
Quoting 92_talon_awd:
Not to troll but I bought a fan resistor pack at Napa for like $15 last year on 464/1000, was even in stock.
LIV4PSI
O-H-I-O
Quoting thruarod:
Is the front steering rack different?
