Gasket question
GVR-4
Asheville, NC USA
Maybe not a technical question, but mods you can move it if you want. Who uses Permatex on the water pump gasket and who doesn't? How 'bout the front cover gasket too?
TIA
89Mirageman
Stantonsburg, NC
I use a very thin coat on the water pump, just enough to cover it. I usually just put a small dab on it and spread it over the entire gasket, put it on the water pump and then repeat for the other side. I use copper spray on the front cover gasket and use a factory mitsubishi one, the ones in the after-market kits are junk IMO.
This is the way I do it and I've never had any issues, I'm sure others have different ways of doing it. This is what works for me.
^ OEM gasket w/ copper spray FTW. Make sure you read permatex labels, some are not compatable w/ different fluids (synthetic comes to mind - turns some gasket makers into like a string-y mess)
