Galant VR4 - Silicone Radiator Hoses
bazeng
Melbourne, Australia
Hey guys,
Do we have these available at all?
If not, are you guys interested?
I have an opportunity to get a custom set made.
They will sell for approx $100.00 AUD..
Quality is excellent.
Let me know, because I can't seem to find any.
JNR
ca
I have a blue upper, but no idea what kind of where it's from...Gonna replace it with a black rubber w/stainless.
Quoting bazeng:
Hey guys,
Are the radiator hoses from the vr4 thesame as the DOHC N/A ??
If so, i could be interested in a custom made set, depending on options/colors...
our you could just use ss hose and an fittings /ubbthreads/images/graemlins/dunno.gif
JNR
ca
^^^What would you do for the ends to connect to the nipple(s)? Unless you have a 'hardmount' AN fitting, I think that looks lame and kind of pointless.
Barnes
Richland, WA
Quoting 9t1tsi:
That would cost waaaay more than silicone hoses.
mean_green
Park City, MT 59063
I want to know how you figure out a shopping list to do an AN fitting setup for your radiator (Along with the rest of the engine bay /ubbthreads/images/graemlins/tongue.gif ). Like is there an adapter for the radiator where normal hoses clamp on or is there some fab work at hand?
Quoting mean_green:
I used a set of samcos listed for an evo 1-3 I believe.
I too used the EVO1/3 Samcos on #1886, and they fit great.
BoostedAWD91
Danville,Pa
Quoting mean_green:
the way i would do it is:
2 weldable an fittings ( size of thermostat gooseneck outlet and radiator outlet, have to check sizes)
2 straight -an hose ends
3' of an hose
put it together and your done.
JNR
ca
If I were going AN route, I'd make a different thermostat housing that contained the male AN (not sure the size) and a threaded hole for the sensor...You could weld a fitting on the radiator (would need be copper), but that point, maight as well chop off the nipple and replace. Problem there is when you need a new radiator, you'll need to do that again.
Are these samco brand you are selling?
Their sites lists parts numbers for "galant vr4 4 cyl" as TCS329/C.
Their EVO III hose kit is listed as part number TCS126/C.
Here.
So which one to order if the evo III fits? /ubbthreads/images/graemlins/confused.gif I wish companies would be more specific and post pics fo each parts so I could see what I'm buying. I want a set in black.
mean_green
Park City, MT 59063
TCS126/C are the ones I bought for my Galant. Work good so far, Im using them with a PWR "civic" style radiator. Bought from sporthoses.com but they took forever to get to me FYI. Just under a hundred dollars I believe.
-Alan
bazeng
So the lower and upper hose of the EVO1-2-3 are ok?
If so, I can get them here already so it'll save me getting custom ones made...
Mark
Naperville, IL
I used gates evo 3 hoses trimmed them to make them fit. They are cheaper then silicone and work the same.
Would anyone be interested in a stainless steel upper coolant pipe group buy?
