Galant Monte Carlo for sale
MX4
New Zealand
Interesting, I thought Monte Carlos were all "Evo Zero" spec with vented bonnets, 510s, 4 bolt etc etc.
raptorWagon
Oak Harbor, WA
Quoting Diego:
It said in the ad that it was AWD, and 4WS.
I didn't know it was turbo'd though. /ubbthreads/images/graemlins/dunno.gif
Why not? The Monte Carlo Editions were VR-4s too.
Base model VR-4s like ours, Monte Carlo Edition, RS, Face lift RS, Evo spec, etc.
fuel
Toronto, ON, Canada
Quoting MX4:
Only the 5 speed manuals. You can still get automatic Monte Carlos which are the same spec as regular automatic facelift VR-4, ie 450cc injectors, TD04 turbo, 3.307 driveline etc.
JNR
ca
so, it's a plain jane VR-4 /ubbthreads/images/graemlins/confused.gif (cloth seats and ugh, automatic) guess I don't see the appeal in it then.
IncorpoRatedX
Arizona
Quoting fuel:
shame it's automatic - they aren't the strongest (in factory form at least) transmission in the world.
wtf are you talking about?? /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif
Not in the world, but pretty freaking strong.
curtis
Clarksville TN
Rumor had it on here from a Russian member that owned one they had a different front to rear spit. Instead of 50/50 was 35/65.
Not positive but if it did I'd like to have the center diff but would also like to have a JDM front 3.307 front ring and pinion as well for the 5 speed box.
fuel
Toronto, ON, Canada
Quoting JNR:
Mechanically speaking it's an ordinary facelift JDM automatic VR-4 (which even with the smaller TD04 makes 210PS, nearly 15hp more than a USDM VR-4!) but being a Monte Carlo edition it's produced in limited numbers, always in Lamp Black (it is NOT Nile Black), always has a sun-roof, missing the fender marker lamps, body coloured rims (which remember is not a usual feature for stock JDM rims) and of course the Monte Carlo 'Spirit of Competition' sticker on the rear doors. If it were a 5 speed manual it would be Evolution spec and therefore would be sporting the big16g turbo, hood + bonnet vents, 510cc injectors, larger intercooler&piping, 3.909 ratio 4 bolt with LSD, close ratio transmission etc. I'm pretty sure you can option the Monte Carlo with the same black leather interior as a Super VR-4 (which has different head rests to the USDM VR-4s).
fuel
Toronto, ON, Canada
Quoting curtis:
Uhmm it's 3.307 because it's an AUTOMATIC, just like the AUTOMATIC 1G DSM. The 5 speed manual Monte Carlo will be 3.909 ratios and they definitely didn't have a 35/65 torque split from factory - perhaps it was fitted with a Cusco Tarmac center diff just after it left the factory?
fuel
Toronto, ON, Canada
Quoting Alpha Male:
Quoting fuel:
Just like any other Mitsubishi automatic from the same era they don't like HEAT and definitely don't like going too long between fluid changes. Unfortunately the stock transmission cooler in the radiator was not up to the task and many did die prematurely, often combined with a lack of fluid changes. Trust me, being in a country which saw many automatic E39A VR-4s on our roads I can tell you the automatics were NOT as reliable as the manuals. However if you fit a substantially sized aftermarket transmission cooler on, and replace the fluid at frequent intervals it can prolong the life of the transmission.
beaner
b'ham, mi
Quoting JNR:
+1 I'd take an equal condition USDM vr4 over that any day.
citymunky
Chesapeake, VA
Quoting fuel:
Quoting Alpha Male:
Quoting fuel:
How do you know so much /ubbthreads/images/graemlins/confused.gif
