G-gsx in the junkyard.
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
What specific parts should I grab, I know these things are a bit more rare than the vr-4's. I'm gonna get the taillights w/ the black trim and a 4wd emblem but I wanted to know if there is any thing else I should look for. I'm unsure but maybe a non-ABS prop valve. Thanks for the help.
Dialcaliper
Bay Area, CA
If you grab the prop valve, make sure to unscrew both of the lines from the master, as well as the front brake lines rather than cutting the prop valve out, as the hard lines are even more difficult to find. Tailights, grill (if it's in good shape), Front one-piece mudflap/dogleg pieces, maybe the badge if you can find someone who needs one, and you can get it off without breaking it.
Other useful things might be the driveshaft (only on the M/T), 22 spline transfer case, Nonturbo ECU, DSM-type 3-bolt rear subframe and power steering reservoir with no 4WS. Also a good source for a DOHC nonturbo block and head if you feel the need. Other things are similar or the same as the VR-4 - Motor moutns, brake and clutch master cylinder, rear brakes (fronts are the same as the early single pot AWD DSM's). Both front and rear struts are the same, as are the control arms. Springs are the same (except on the GGSX M/T, where they are slightly shorter in the front with the same spring rate). Fuel pump and sending unit should also be the same. The list goes on.
curtis
Clarksville TN
rear bumper and mounts due to the fact the fwds have a different one and the gas tank and sending unit.
ggsxkid
La vergne TN/Lake Zurich IL
does it still have a tranny in it???? if so how many miles are on it???
but more importantly as someone already said about the control arms. i need a pair. let me know if you can get them off the car for me and whether or not they have good ball joints. this would be greatly appreciated as my pivot points on my current ones have rusted down and are very thin, not to mention they clunk pretty bad now. thanks.
Adam
