Fuel pump rewire help
James
Port richey Florida
I have been reading the vfaq on it for a couple of days but honestly some of the things on VFAQ are written out the best. I'm sure it much more understandable after you do it... But I'm also a hands on learner not a read and learn guy. Couple that with the fact that I dislike wiring and it means I need a better explanation lol.
Of the two... The one linked to Plymouthlaser.com made the most sense.
I understand the galant wiring also runs a different way than pictures in the writeups, atleast mine apprears to.
I know what I need to buy
I know the plug and wire I need to cut
I know how to put the new wires into the relay
I know what wire gets run to the battery
After that is where I get confused and could use some help!
MellowVR4
Milwaukee, Wi
If you buy the kit from ebay or any other place, it should come with some instructions, better then the vfaq info. I was also confused on how to do this, but once i read the instructions that came with the kit, it was all good after that. i belive i got my kit from ebay to tell you the truth.
James
Port richey Florida
Well there's 4 wires. The ground and power are obvious. I assume the other two get spliced between the original? I just don't know what sides is which
