Fuel pump re wire
bcallahan92
Browns Mills NJ
Just an update, couldn’t really find a good post on it. Yes there’s many but all rambling and not good info, atleast for me. Hopefully this will pop up and help people out.
Run power wire from battery 10g. Attach fuse 30amp in between power wire to relay.
Ground to relay.
After connection to pump. Cut black and white wire. You’ll run one off the connector to the relay.
The power off the relay run it to the other cut black and white wire to sender unit.
BK/W is power
BK is ground
Yellow float
Yellow/Blue/low fuel light
