fuel on intake manifold
steve
NJ
I noticed a bit of gas puddled on top of my manifold. I assume there's a leak at one of the injectors. Is it going to be the top o-ring that would leak gas? If the bottom were leaking, it would be air right?
ken inn
krum texas
most of the time, the fuel is under really high pressure. it can be squirting out, hitting the top of the hood, and puddling. this is SO dangerous. maybe energizing the fuel pump lead in the engine bay and looking around might help you find it, but man, sparks, etc, with the hood open, if the spray is fine enough, it will explode
atc250r
Orange County, NY
Yeah, its probably the top seals. You can run the pump with the logger and if you need to you can pinch off the fuel return and that'll put a lot of pressure in the system.
John
JNR
ca
Just don't be this guy, chacking under there
I imagine you've done it before, but the O-rings/seals are easy enough to change...just use plenty of lube (dielectric grease, etc.), to keep them from tearing...
atc250r
Orange County, NY
Yeah, he just did them not too long ago which makes me wonder why they are leaking. Let us know how you make out Steve.
John
steve
NJ
Good news is I found it. Its the #1 (? closest to drivers side) injector pissing from the top seal. Now I have to source a new one with the quickness. Thanks again everyone. One more problem/solution for the archives. I couldn't find this problem when I did a search. /ubbthreads/images/graemlins/wink.gif
JNR
ca
Denso or FIC/PTE injectors?
I sourced my stuff locally and here's what it comes out to:
Denso only uses one (1) large @ 12mmOD/8mmID x 2.5mm Thick; the FIC (and imagine PTE) uses two O-rings, one large like the denso and a smaller one underneath that acts like a spacer: .450"OD/.210ID x .075 thk
I have some, but would be impractical to ship them, I'd think...
steve
NJ
They Evo8 injectors, so Denso. I think I need MD614805 based on this thread but I don't see that listed on the JNZ site. They have the insulator (MD087060) that goes in the head, and the small o-ring that goes on the injector (MD614813). /ubbthreads/images/graemlins/banghead.gif
Actually, I will order the o-ring that goes on the injector too, in case that is torn. But I want to order the MD614805 too.
steve
NJ
Yeah right? Charles thread scares me. I've got JNZ on the phone, he said the top piece ( called the "injector sheet" /ubbthreads/images/graemlins/dunno.gif ) doesn't really seal anything, its probably the o-ring. I ordered the o-rings since they were in stock. We'll see if thats the problem.
Polish
NE, IN
I tried ordering everything new from Erik at JNZ when I put my 510's in. I asked for all 3 injectors seals/orings/whatevers and the rail isolators. He said there were only 2 per injector, the top oring and the lower seal in the head. Well I knew there were 3 because I had an injector with 3 on it. Anyway I just agreed on the 2. When I went to put them in I just used the black insulators/seals that were on the top of the 510's already. I did install new Orings, Rail isolators, and lower head seals though. So it seems the top things are reuseable. Well they better be because if mine leak after all this I will not be a happy camper.
steve
NJ
Go directly to Home Depot and get a small fire extinguisher before you head home.
John
I left work real early today (before your post), but I'll be swiping the extinguisher from under the kitchen sink until I get these parts in.
steve
NJ
Crisis averted. /ubbthreads/images/graemlins/grin.gif The O-ring on that injector must have gotten pinched and torn. I replaced all 4 for good measure. Took it for a ride and the idle feels more stable. Maybe tomorrow I can set up the baseline on the SAFC.
steve
NJ
Ungrateful POS. Looks like the clutch slave cylinder sh*t the bed. /ubbthreads/images/graemlins/banghead.gif
JNR
ca
It's raining men! (you guys with wives, will know that Lifetime jingle)
