Fuel cut
Jesh
Soldotna, Alaska
Keydriver might know the answer to that one. but to my limited knowledge on that subject i would probably say no.
vtecds1
Las Begas
I'm trying to find out online how Al Blaha modified his mas. If you can find a how to, that will eliminate your fuel cut problem.
Jesh
Soldotna, Alaska
Remove the smaller of the two honeycombs in the MAS - Do NOT remove the larger one. This modification will allow 2-3 psi more boost before hitting fuel cut.....
Complements of Buschur Racing /ubbthreads/images/graemlins/grin.gif
HKS fuel cut defender or whatever it's called. Your best bet is to go get a chipped ECU through Jeff (keydiver). However, I'm not sure if he is still doing it. His website said something about how he's not a while back.
