FS: Turbonetics Raptor BOV ready to install
curtis
Clarksville TN
Real turbonetics valve not a cheap ebay copy. Valve with flange on your size pipe already welded on. I have plenty of pieces of different size tubing and can weld on the flange and bead roll the ends and bead blast after welding. So all you have to do is cut out a section of your pipe or add to the end of on of the pipes. Up to you. Have 2.25/2.5/2.75/3.0 aluminum pieces in a big box if you want it on an bend I probably have that as well.
Valve works fine, local guy went to a different brand and I already have what I'll be using so this needs to go.
Valve has a o-ring built in the base for a full seal, and valve stem also has a seal and top has a full adjustment screw to increase or decrease pressure per your application.
You can find more info on turbonetics site I'm sure.
Here's what one sounds like
click me
These valves run around $200 and don't include the flanges or tubing ready to go.
I'll take $175 for valve shipped to include the pipe ready to put on. Valve needs a little hand polishing but looks alot better than the pictures below. Sorry best I could do.
Paypal is [email protected]
Thanks Curtis
curtis
Clarksville TN
I think the greddy flange is the same animal. Just get me some dims and I'll measure it up for you. Thanks
