FS: supra tt pump
mikus
Aurora IL
I've been meaning to get a tech post up - buyer, I'd strongly recommend a quality relay in the 30amp+ range with sufficient gauge wire.
The ND Supra pump can and will overrun the usual 20amp relays commonly installed on our cars.
s_firestone
Park City, UT USA
Thanks, definitely a good idea from a safety perspective. Not only the danger of overrunning the fuse, but having the wires heat due to current.
I may also look into how the evo toggles the fuel pump voltage at idle Ooooo, I could build PWM fuel pump controller.
s_firestone
Park City, UT USA
Any input on which fuel sock I need or does it matter? Can I get a Walbro install kit and use the parts?
I'll be happy to document and post pics for a proper howto.
talontyme
Portsmouth,VA.
Factory 2g sock is what i would use don't know if the 1g/vr4 is the same but that will work also doing the 30 amp relay mod us a must.
